Is someone willing to make this part for the Leathercrafting SIG?
In the Creative Arts / Leatherworking cabinet we have two Strap Cutters. This piece is missing from one of the two strap cutters. A new strap cutter costs $24. While a small block of wood might work for a time, I’d prefer a metal replacement piece. The replacement part doesn’t even need to be exactly the same size. There is easily a 1/8" variation that would work on the width. It does not need to be as thick either, it need only be thick enough to have a hole for the bolt, that pushes against it so it stays centered. The actual part is threaded, the replacement part does not need to be.
Any takers? I can provide better measurements if a volunteer has the skill and inclination to help us out.
This is a strap cutter
This is where the part goes
This is what the part looks like from a few different angles.
