Could someone please measure the lift? I just need the width at its widest point - either the base, or the columns.
Nearest 1" is good enough for what I need.
Thanks in advance.
Thanks in advance.
Bendpak and Rotary 2-post asymmetrical 7000lb lifts are between 125-126" in width, depending on specific model revision.
Whoa! Only 100" between posts. I could be off a bit – Stan and I were measuring under the car that was only up a couple of feet…
Measured from base to base? Or sled to sled?
Inside edge of post to inside edge of post. About 1 ft up.
OK, thanks. If it was inside to inside, that’s reasonably consistent with the 125 - 126" total width cited above.
Thanks much for measuring it.
Chris,
Please use 165.75" for a dimension for the distance from the outside edge of the two lift columns (those are the specs from the lift manufacturer that I am looking at for a new lift)
inside dimensions would be 110.6 between (as a drive through dimension).
Thanks!
