Can I reglaze/refire?
So I made a dish and my glazing came out poorly. Seems that it was too thin. Can I just reglaze it? The glaze was Amaco Ancient Jasper.
Yes. People do that regularly. Since your piece is fairly flat, you might not need anything to help keep the new glaze on the piece. That looks really thin, so I’d do at least 2 coats. Some people use hairspray or something similar to help the fresh glaze stick.
I, personally, am not a re-glazer. These are just things I’ve read here in other posts.
I quite like Ancient Copper but find that it needs multiple, smooth coats to get that really metallic sheen. The pot below has three coats applied with a hake brush. Flat things are way easier to reglaze, I say go for it if you are unhappy!
(This happens to be on Spectacular, but my results are similar on other clays.)
Thanks! I think I will!
