I just can’t get the Fusion 360 shell command to work correctly. I assume it’s operator error.
I want to make a rectangular brick that is hollow on the bottom. I’m not getting any type of conflict or error message, so dimensions don’t particularly matter.
I sketch the rectangle, extrude the face, and then shell it. If I use the shell command and select the top face, it creates the shell correctly. I can select the inside face of the shell.
However, I don’t want the top face shelled and I’d prefer to not build my part upside down. If I use the shell command and select the bottom face, it appears to leave a skin against the bottom face. When I try to select the inner face, I can’t - it’s obstructed by the “skin” that is still there.
I’m using Fusion 2.0.7830 on a Mac. It doesn’t think there are any possible updates.
Thanks!
