When is the next Bridgeport Mill class ?
I need to machine down front hub caliper mounts
here is the link: bridgeport class
Do you know how you are going to fixture it for machining? That is going to be the challenge so things are kept in alignment. After the class I suggest you buy your own cutter so it for that type of material and sharp. You can use one of ours, one of the βnewβ regrinds would probably do it.
