Oh, look a few posts back. Already had to replace the rear ABS hydraulic valve. This sheered off when I thought I was nearly done.
ain’t that just the worst…like moving goalposts.
Gentlemen, thank you all! After first discovering this leak July 2020, It is repaired! For the first time, possibly since I got it, there was no fluid of any kind under the truck.
One new Rear ABS valve, 4 brake line adapters to connect everything up, and one new rear wheel cylinder. Under $200, and I had enough excuses to buy a few new tools
The brake and rear abs lights have decided to stay on, which I’m betting indicates either a bad abs sensor or a bad connection to that sensor. Which is something to fix but nothing that prevents the brakes from stopping.
Best part, I have a much better idea of how this system works @jast, you were right; pretty simple.
