Hi all,
I plan on using the slab mill for a bit and wanted to get some replacement blades to change before or after use. Can anyone confirm the dimension of the blades on the bit? Would 14x14x2mm work?
Thanks,
Sravani
Hi all,
Thanks,
Sravani
No the bits are 12 mm x 12mm x 1.5 mm
Here’s a link where you can buy them
BINSTAK - K1215 - 12mm Square… Amazon.com
Here’s a link the bit we use:
CNC Spoilboard Surfacing Router… CNC Spoilboard Surfacing Router Bit, 1/2" Shank 3" Cutting Diameter, Carbide Insert Slab Flattening Router Bit Planing Bit Wood Planer Bit Woodworking Tools by BINSTAK - Amazon.com
Thank you!
