For anyone interested, my neighbor had a large black walnut tree cut down. There are huge pieces available on the curb if you want them. Full disclosure, the tree was hollow and had bees but some pieces are still pretty solid. The tree was 2.5 - 3 feet in diameter.
The bulk trash pickup is this week but there’s never any guarantee which day they come (likely not until Thursday). The address is 7223 Piedmont Dr Dallas, TX 75227.
Hrrrm I did enjoy turning a little puck of black walnut someone forgot to trash in a lathe chuck the other day. Storage is an issue for me though @indytruks138 you bring a chainsaw I’ll help load, that’s not weird right?
If it’s still around I might be able to swing by with my chainsaws. Just can’t afford to make the trip and it not be there. Lots of bowl blanks there I presume…
As of about 5pm Tuesday, I have grabbed 5 of the easier to find sections. There were at least two nice ones still in the open when I left, and several that while the core was rotted out would still likely produce nice platter and shallow bowl blanks. (Please be careful of bee hives and a few stragglers that did not follow the colony wherever they swarmed). There is also a remaining pile bigger than an F150 that is branches and whatnot on top that I expect has a lot more trunk and heavy branch sections under it. This was a big tree.
I’m a little sore after loading and unloading that solo.
If you go digging, please be mindful of a couple of young trees planted behind the pile and not topple or stack branches on them, or so near that bulk pickup with the grapple might accidentally grab them.
Ok Superman, I want to know how you got those by yourself. They are at least 700 pound sections. Marshall and I got a couple smaller ones and Pat and I went back for one of the larger ones.
The right mechanical advantage helps considerably, but it was still a major effort. I’ll admit tipping them over, and changing where they were aligned was a challenge, and standing them back up was even more fun.
Whatever you do, you don’t ever want to have them come back down on you, or fall off the side on you.
I will also add, I refused to be below them when lowering. Too much risk of them getting away on descent. I set the ramps a bit further apart, and tied a line to the trailer hitch, which in turn wrapped over the log, and to a bridle from both front tie points, with a block and cleat. In hindsight, I should have had just a heavy (1,000 lb rated) caribiener at the bridle, and run the line to the block and cleat at one of the rear tie downs. The friction of the rope running through the caribiener would have provided a welcome reduction in holding force while lowering, and made it easier to watch and guide the sections onto the ramp while standing in the bed. I did have a couple get away in the bottom foot of the ramp, but neither went more than a couple feet in any direction.
Pictures from this morning. Mostly hollow pieces left but underneath the leaves and branches are some smaller pieces that were the higher up branches. The pictures might make the pieces look small but like in the second one, those pieces are at least 2ft long.
