For trebuchet weights, we need to make 18 concrete disks, each disk is 24" diameter and 1.625" thick (about 0.44 cubic feet per weight which is 1 $3 60lb bag) and will have a section of steel pipe in the middle with some rebar welded to it. Total amount of concrete used will be ~8 cubic feet of concrete.
Anyone have an idea on the best way to make these?
Could we find some 24" sonotube somewhere for cheap? Would it be worth renting a concrete mixer?
The entire depth of the weight on each side needs to be less than 15", which is why the diameter is so large for the concrete. Using steel as weight instead of concrete would be >3x more dense, but also >10x more expensive, $500 vs $50 for 1,000 pounds.
