I pulled the blade off and tested the saw and the wheels were turning true. I replaced the (same) blade and adjusted the tension and pressure on the guide bearing and the weird movement cleared up There is still a weird vibration in low gear (enough for the machine to move) but that may be how it is currently positioned. We need a couple of people to help turn in back into position and to check that it is level. Someone other than me should look it over to make sure it can be put back into service.
We need to change the blade again. @Photomancer - did the blade I asked for on the MSC order make it onto the order? Nothing was received but that doesn’t mean they just weren’t out of them. We should get a couple of pre-welded blades as soon as possible.
Hopefully we can be back in service in a couple days. cheers!
