Band saw has an Issue
I’m not sure what the problem is but the band saw is vibrating so badly that it is moving around the room. It’s sitting at around 30-40 degrees from it’s normal position. The blade is flopping around in it’s guides also. I saw some people use it but it did not look safe to me.
it is likely not on a level plane. I’ll check it out when I get there.
thanks.
-Nick
the bandsaw definitely has an issue. I had to teach a class so didn’t get a good idea of what’s going on but the blade is not moving as it should. I’m out for about 5 days so if someone else can please take a look that would be appreciated.
Could someone please put an OUT OF ORDER or comparable sign on it until someone can check it out?
Done.
_ This is a complete sentence.
