Do we have larger ball end mills in the 3/4-1" range?
thanks much
Not that I’m aware of. What are you planning on milling with it?
Aluminium.
No I mean, like what are you making.
A jig to collect an instrument response function for a device I’m building- a bit hard to explain. The optical geometry is different, but this is the idea: https://doi.org/10.1364/BOE.380996
Yeah, if you need the long reach we have about 500 1/2" square end mills. If you need a ball nose specifically we have a couple thousand smaller ones even down to 1/16".
If you really need one specifically, I’d just go buy one. We have what on hand what we need for the classes and whatever people donate.
thank you- where are the smaller ones located? I expected I’d need to buy the large one, but there are some smaller groves.
Get one of the teachers to pull a couple for you out of the teacher’s cabinet. Ask them to not give you the same size as we use for the domino project.
If you don’t mind, once you get someone to give you a couple leaving them in the HAAS toolbox with a note under them saying general use.
