Alper,
Tom and Zach are correct in fixing this ASAP, but you need to identify which is the cooling fan, and which is the A/C (also known as the condenser) fan. Get both fans running and then shut off the A/C just long enough to identify the fan that stops running. Is it the same one that you have to bang to get it going? Then that is your AC / Condenser fan.
Or you can use this diagram to make sure:
The radiator fan is on the passenger side and the A/C fan is driver’s side. (you just answered)
Call McCain’s - 13566 Floyd Cir, Dallas, TX 75243 972.669.0669
and make sure they have the part in stock and then go pick it up - PREFERABLY IN ANOTHER VEHICLE to minimize the chance of further overheating. What is also a decent idea if you have the luxury is to pull the bad fan out to match it with the new part which is another reason to use an auxiliary vehicle. It isn’t too bad of a job, but typically you have to wrestle the fan shroud out and the connector can be a pain to disconnect.
One problem I have seen is that the electrical mating of the connectors can oxidize and start heating up, to the point to where I have had the connector housing melt.
If the price is cheap enough, you MAY want to consider replacing both fans as 12 years is awhile and if one has gone, the other may not be far behind. Just take photos beforehand and label your bolts to ease re-assembly. (I use a plastic parts container with masking tape and a marker - do it in the order of dissassembly and then work backwards)
(and likely fan, as it could come as an assembly)
True - Honda fans often come as an assembly.
(oil changed week ago but still)
NEVER trust someone else with your oil level, fluids, tire pressure, etc. - ALWAYS verify it yourself. I lost an engine because David McDavid Acura (the first Acura dealer in the U.S.) did not check this properly even after I brought back the car for the 1,000 mile “checkup”. They made some strong concessions, but I will be goddamned before they ever touch another vehicle of mine.
Also make sure your coolant overflow tank is up to level. If you have to drive the car, remember the heater dump trick that Tom and I mentioned. It has saved me several times, but the one thing it will not patch for long is you lose coolant from a leak. Then it may just buy you enough time to find a good “ditch-out” location. And if you can do this in the morning before it gets too hot, all the better.
JAG “Late Night Honda Repair DJ” MAN
