Automatic center punch
Our automatic center punch is now just a center punch. It seems to have failed. I don’t see any way to open it to figure out what’s broke.
Not the DMS one, but I spent most of last weekend using one that wasn’t happy. On that one, both the top and bottom 1/4 of the handle unscrew. I think on that one, the issue is the spring in the bottom section that is wound in two diameters, on two non parallel axis. I think the larger diameter was slightly shorter than it should have been, resulting in the tipping pin not escaping the center bore of the upper plunger, to kick out to the side of the “funnel” that generates the automatic action.
