probe off vertical and loose. Autofocus doesn’t work(aka: will keep going up unless you hit E-stop)
Just wanted to give a heads up to whomever it is and such.
https://dallasmakerspace.org/cgi-bin/updatetoolstatus.cgi
Updatred tool status to yellow on laser.
At this point since the spring is “gone” I think the committee might want to consider purchasing a 3rd party spring and cut to fit since the probe has been “dropping” during cuts and moving individual cut items around (like tokens)
This topic is now closed. New replies are no longer allowed.
This issue was previously resolved. It’s been a recurring issue as a result of a poorly designed auto focus plunger, combined with less than careful use of the laser.
Feel free to continue to report when the plunger fails, so we can do our best to ‘fix’ it when it recurs (and it will…). Please keep in mind that even the manufacturer suggests that it’s best to use the manual focus method.
See related post here:
Thanks!
Lisa
Laser Committee Vice-Chairperson
