I am doing a school project where I am making a autonomous plane that can drop off medical supplies. I got the plane build and the apm2.6 set up and wired. When I am in manual mode it works fine, but when I am in fbw or autotune the control surfaces only move a very little amount. How do I adjust this? Also it says my vertical speed is 15m/s when I am still, I am indoors is it a gps issue?
I can help you out, but would need to meetup to go over it with you.
That would be perfect, when are you available?
evenings are usually good or tomorrow. whens best for you? text me Russ nine 7 two 672-367seven
Sounds good (character limit)
