I just pulled my 2012 sentra cvt apart for the 3rd time trying to fix this trans. The first time I discovered a sticking ratio control valve. I polished the steel piston and got it to stick less but ultimately it didn’t fix it, I should have polished the aluminum bore until it stopped sticking completely but it may have cause sealing and pressure issues. So for attempt #2 I ordered a “cleaned and tested” valve body, packed in dirty trans fluid of course. It threw a solenoid code and I over filled it this time without realizing it.
So now on the 3rd attempt, I pulled the replacement valve body and now the ratio valve piston is sticking in it! I’m thinking I’m going to go back to the original valve body and polish the bore of the ratio valve. A replacement at this point would be a week away.
