I have a test project under development and need guide blocks something like the attached photo. All are 0.5" thick x 4.25" long.The holes are 1.625" from one end. Through hole is 0.25" in diameter, the counterbore is 0.375" in diameter by 0.325" deep.
These are guide surfaces for router bit bearings to ride against, so need to be hard and durable aluminum or plastic. Ideally, these would be produced in sets containing all these sizes and with these quantities:
40 blocks 0.375" width
30 blocks 0.5" width
25 blocks 0.625" width
Prototyping with wood, but want a final design that does not swell/shrink with humidity.
Need low cost that meets specs:
What material other than aluminum should I consider?
What making process is a good fit?
Would any Makers be interested in being a supplier with the expectation of repeat business?
First off, I wouldn’t do the .375 counterbore on a .375 wide workpiece. Even your model shows it breaking thru the wall. It will be sharp and even with a tolerance of .005" you’re probably going to get an uneven breaking of those walls. I would do a spiral ramp into that counterbore unless you’re using a reamer.
Delrin is a hard plastic but it’s still going to flex on you. Personally, I would hold these in a vise and cut them all from the same width material (.75 wide). Cut the profile to the corret width, and the holes. flip them over and cut the flange away to the needed depth. Rinse and repeat.
A quick Google reveals that Nylon might be a good choice.
“Acetal Copolymer + 30% Glass Fiber” and “Polyimide + Glass Fiber” also popped up as possible plastic choices. I presume “glass fiber” would be rough on endmills.
I’m curious how this is used with a router and how only one mounting hole is needed? Are you using both sides as a guide, there’s usually some slop if using a threaded bolt to mount, might consider a shoulder bolt. And skip the counter bore if you can live without it unless you are using cnc, otherwise you are in for lots of tool changes.
I think dominos are usually made from Acetal. I wonder if Acrylic would work? If so, easy to produce those parts en masse from an appropriately thick sheet on the multicam…
