I’m looking to pick up some of the kind of shelving they use in retail stores (the same general kind we use for the Free Shelf). There seem to be a few Craigslistings, but I figured I’d ask here first just in case.
My preference would be for single-sided, two 36" modules, with 14" or deeper shelves, 5’ or taller. But I can deal.
I have some that I might be willing to sell, but they don’t quite meet your specs.
Single sided: Yes, but see below.
36" wide shelves: Yes
14"+ deep: Yes. The bottom fixed shelf is 16" deep. I can supply a reasonable number of 14" deep movable shelves.
60" tall: No. Mine are 53.5" tall, including the casters.
Other: They are on casters. The rear casters are on legs which stick out 2.75" horizontally behind the unit. They are old, used, a little beat-up, and dirty. Not pretty enough for a retail store, but maybe a thrift store. Some of the casters are bad or mismatched. The frames are beige painted steel. The front and rear panels are simulated woodgrain. The front panels could be slatwall if you wish.
How many movable shelves do you want per unit?
What I’m trying to do is put some shelving into this storage unit that I’ve rented. Its far wall is 7 feet long, so two units 3 feet long could fit comfortably. I’d put the larger/heavier stuff on the bottom shelf, & then probably 3 or 4 of the movable shelves above that — better to have too many than too few.
Are the casters removable?
Yes, the casters are removable. Each caster has a single stud which screws into a tapped hole in the frame.
They’re in Mesquite. I know that I can put one unit in my truck, but I would have to take some measurements and maybe do some trial and error to see about transporting two simultaneously.
4 shelves per unit is fine. Some of the shelves in the photo are 12 inch, but yours would be all 14 inch.
About how much would you want for them? And when would it be possible to pick them up?
Please make an offer. Afternoon or evening pick up would be better. Please give me about a day’s notice so that I have time to extract them from my overcrowded garage.
Thanks.
Sent you a private message with my telephone number, as that may be the better way to continue this discussion.
