I use my thermal camera attachment to look at microboards or other devices for sources of problems. I have a picture of one of our microboards with a processor temp of several hundred degrees. As well as the voltage regulator was hotter than hell as well. That ended up being a short on an input.
That is brilliant. Means if you wanted you could do really high-energy chemistry.
Don’t know if you follow the research on molten salt nuclear reactors, but they are something that would really revoloultionize energy, (make it truly safe, unlinimted and scalable) and the major stumbling block is materials that can resist corrosion by molten salt.
So when and where is first meeting of the team? When are you at the space?
I will be there Thursday night. I am one of the tour guides.
