The CX-400 came with either 4 or 8 1 Gb connections. I know the CX-200 only had 4, and I know the CX-600 had 8, but the CX-400, as the middle child… I can’t remember for sure. Regardless, my point was that it will only log into a switch at 1 Gb. Modern FC SFPs (8 Gb or 16 Gb) will simply not run at 1 Gb speeds. You’d need an FC switch at least 8 or so years old or older to make this array work. The only link aggregation for these arrays is what you set up in the multipathing software on the host side, and honestly, due to the active/passive nature of this generation of Clariion, there’s only one good way to set that up.
Okay, whether or not what you want is actually possible depends on what you mean by a “scrub.”
If you mean a good, solid, certified data erasure where you do multiple passes of writes to the disks (00000,11111,01010,10101, etc.), then you’re flat out of luck. These arrays weren’t capable of that internally. EMC Engineering had a separate appliance that had to be shipped around the world and hooked up to arrays like this and left to run for X amount of hours (where X was usually in the range of dozens of hours). The Engineering guys only ever put together a bare minimum numbers of these appliances, so sometimes you had to wait weeks in the queue to get it shipped so that you could do a full array erasure. Needless to say, if these appliances still exist at all, they’re probably in a closet somewhere in North Carolina and even when they existed, the services offering to use them was like $50k or thereabouts. You’re not getting one.
If you mean that you just want to log into the array and wipe out all of the LUNs and RAID groups, then, sure, you could do that. Or… I have a much easier idea for you. Pull every other drive, drop it from about 5 feet onto pavement, and then put it in a dumpster. Wait a week, repeat the process for the other half of the drives. Honestly, this is probably overkill and what you could do instead is just shuffle all of the drives around within the drawers right now, set all of the enclosure IDs to 0 (that generation of Clariion DAE had switches on the back where you manually set the enclosure IDs), and scrap the whole thing. The amount of effort required to recover ANY meaningful data from the array at that point is truly colossal. Sure, if it contained massively important state secrets, then it might be worth it for someone to figure out, but even if it contained 100,000 stale credit card numbers and personal data, it just wouldn’t be worth it. Sure, technically, teeny tiny chunks of data would be identifiable here and there on the drives, IF you could actually attach to the individual drives, which isn’t trivial. However, that’s just as true whether or not you delete the LUNs and RAID groups on the array, since that doesn’t actually scrub the data from the drives at all.
The “third” option is just a pile variations on the second option, but you replace the 5-foot-drop with other forms of physical torture: strong magnets, extreme heat (a nice bonfire, but, y’know, that’s a lot of burning ABS and solder, bring a breather), or, as some others have suggested, an actual drive shredder. Those services cost real money (a super-quick Google search shows that you’d be looking at around $5 per drive x75 drives + tax, you’re looking at $400), and I really, really think it’s overkill unless you’re storing something that you don’t want the North Koreans to get their hands on.
Seriously, you could shuffle the drives in the drawers right now and take it to an electronics recycling place and know with a VERY high certainty that no one is ever ever going to get at that data. If you want to be one step more paranoid, take half the drives to a different place or separated by time, or whatever. And the next step more paranoid is various levels of physical destruction.
But getting the array up and running for a “scrub,” depending on what you mean by that, either can’t be done any more or is kinda pointless.
Sorry, man. It’s junk. Junk it.
