While our rooftop antenna isn’t up in the air, would there be both interest in, and approval available for the following idea? I have access, on a bottom of the list basis, to a friend’s 50 foot tower trailer that takes about 4 parking spaces to set up, and I can likely also borrow a rotator and Mosley 10/15/20M 3 element beam. Set up time, including beam is anout 90 minutes with crew that hasn’t helped before, and about 45 min with an experienced crew. Take down is usually going to be 30 min to an hour with the same qualifications.
The proposal would be that roughly quarterly, I could bring it up Friday after work, get a couple of people to help assemble the beam, and stand it up. Sunday evening, also find a couple of people committed to taking the beam apart and packing it back up. The 48 hours in between I would propose should have a sign up sheet for 1 hour blocks of reserved time, with some rules about maximum block size and maximum number of hours that can be reserved on a weekend. Time not booked would be first come, first served with preference to those who have not worked reserved time.
To make this happen, I would need to know that people are committed to helping me set up and take down. We would need assurances that the periodic weekend set up and 48 hours in the parking lot was unlikely to be an issue with the landlord and that the board and infrastructure have no objections. After all, it would not be good if this difficult to handle combination wound up towed/impounded for trying to be generous. Based on the current AR sig bench, and the apparent access to a wall penetration for coax and rotator control, this would likely be somewhere along the north end of the building, but I havent specifically scoped out a minimum of 50 feet from the power line easement and clearing the trees.
Anyone have any thoughts, questions, or concerns?
I can confirm in advance that bigger amateur radio weekends like field day, winter field day, Texas state parks on the air, texas QSO party, and a few others are not going to be available. This would be more generally non contest weekends, but good opportunities for general operations.
