TSki
January 12, 2022, 2:56pm
6
Using the drum sander is fairly easy - just take very little off each pass [around 0.006"]. A really good write up on how to operate it can be found here:
As many of you have noticed, the drum sander has been missing sandpaper on and off for about a week or so. When I was up there during prior to this I was having to change it out 2-4 times a day due to tears or excessive burn marks.
This post is to explain proper usage, tips and tricks, and to address issues I’ve noticed many members having using the Powermatic 22-44.
This machine is intended to flatten material - sanding it is a byproduct of that goal
Control Panel
[20180820_230748]
Indic…
Tom
