Adhesive for 3D parts and 3D print question
There is plenty of info out there re gluing 3D parts including just melting with acetone and sticking together.
I am thinking about a small part I would have to make in pieces due to the internal support needed to print. What do you favor for gluing together an assemby of printed parts?
While I am asking this question, maybe my assumptions are wrong re the printing problem so you can tell me what you think about it as well.
In simple terms, my part is a cylinder that has a flat top. 0.6" dia cylinder 0.6" tall with 75 mil thick wall and a top that is an extruded circle with a thickness of 25 mil.
I am thinking about printing the cylinder and the top separately and gluing them together. The inside must be totally clean without struts or support.
The superglue (Cyanoacrylate) works pretty well for small parts, you really donā€™t need a lot either.
Any ideas for how acetone and cyanoacrylate compare to other options?
Iā€™d like joints with strength on par with the ā€˜homogeneousā€™ printed material - in some cases with a fillet, in some cases withoutā€¦
From product packaging, it appears that these might work -
Plastruct Plastic Weld (Methylene Chloride & Methyl Ethyl Ketone)
http://www.amazon.com/Plastruct-Plastic-Weld-applicator/dp/B00FDFWJD8
Plastruct Bondene (Methylene Chloride & Methyl Acetate)
Plastruct Bondene 2 oz #bond-2
Loctite Epoxy Plastic Bonder
http://www.amazon.com/Loctite-1363118-Plastic-Bonder-Syringe/dp/B0044FBB8C
JB Weld ClearWeld
http://www.amazon.com/J-B-Weld-50112-ClearWeld-Syringe/dp/B009EU5ZM0
JB Weld PlasticWeld
http://www.lowes.com/pd_556899-81288-8237_0__?productId=50149638
Just wondering which might be best for different applicationsā€¦
@rice81 & @cottjr - David & Carlā€¦ Thanks for posting GREAT questions!
@themitch22 - Mitch, Thanks for taking the time to respond!
Iā€™m definitely leaving this topic open, as I know we have several members who have printed large and/or complicated objects that required ā€œgluingā€ so to speak.
I believe most members either use Super Glue (aka: ā€œcaā€ / Cyanoacrylate) or at times ā€œABS glueā€ (which is just abs melted in acetone to make a mixture that will ā€˜meltā€™ the pieces together). From what I understand, both work pretty well. Personally, I have only used the ā€˜ABS glueā€™ one time - because itā€™s easier to pick up the super glue than it is to mix up a small batch of the ā€˜abs glueā€™ā€¦ :wink:
Hopefully others will share their experiences, too!
Thx agian!
:smile:
I usually use superglue for small, non structural parts. You should consider adding pins or tabs in your design to join larger parts to increase the structural integrity. Though I havenā€™t used it personally, Iā€™ve heard that ABS glue works really well. I made a helmet for Halloween this year that printed in several parts. I used my 3Doodler (handheld 3D printer) to weld the plates together with a classic butt weld. I used the heated tip to join the pieces and create a bit of a trough, then came back and filled the trough with filament from the 3Doodler. I did it on the inside of the piece, but was able to sand down the seam and it held very well, especially considering the wall thickness was about 3-4mm. About halfway through construction the 3Doodler crapped out so I used a soldering iron to fuse the rest together. That worked really well. PLA joins good this way too.
my 2 centsā€¦
patrick
Cool thanks!
FWIW, there once was a TV episode on a poor country, where they showed a street vendor using a soldering iron to repair all kinds of plastic items - I distinctly remember seeing a moped fender getting a significant rebuild this way. In fact, that provided inspiration to use a soldering iron to repair a part I broke on my dishwasher (since none of the glues on hand would work)ā€¦ 2 weeks later and itā€™s still holding up fine.
I recently did a repair on a rather large hole in a large plastic diesel tractor fuel tank that was going to cost and arm and leg to replace. I used a device sort of like a cross between a soldering iron and hot glue gun (poor manā€™s 3Doodler!) and a hot air gun. I removed the chunk of cedar. (Rotten luck! There was only one vulnerable spot where the tank was not armored and that stick found it.) Next, I heated the area with a hot air gun and fashioned a hook out of a metal rod and pulled the plastic back in place. Next I sort of applied the ABS rods through the plastic doodler while semi melting the tank plastic with the doodler. The thing was rock hard when I finished and is good so far, two months later. It was a $60 plastic repair kit from Amazon
but you can get the same thing from Horrible Freight for around $15
It sort of showed me that plastic things can indeed be repaired. See more info on youtube - plastic welding. I learned a whole new repair technique.
thatā€™s awesome - thanks for sharing!
