I just ordered a new add on member on the member portal. I was wondering how I can setup their login info for the computers, classes, ect. Also can we get their key fob.
It should be you go into Maker Manager under the member portal drop down in the top right corner. Then sign in (should be option -MakerManagerBadges). Next go to the My Badges drop down at the top and you should have one that is unallocated. Hope that helps!
Edit- the key fobs are in a box in the galley in a variety of colors. When you enter the galley go straight back and at the end of that first row of storage pins is one that’s about chest/eye level that is half the size of a normal bin. They’re in there. When you go to assign an add on you can add the fob number for activation at that time.
Thanks, do you know where I can find the badge number? I added the family member and now it says to insert the badge number.
Look closely at the badge itself, the number is printed in the middle. Should be about 10 digits.
I have not gotten the physical badge itself yet, do i have to do that first?
I’m not 100% sure about that as I did mine all at the same time. You can do it right there in the computer lab next time you are at DMS.
Yes the number is only on the badge or card so you need to have it to activate it so they can get through the doors.
