We have a code one, member needing to order stuff from Adafruit at massive quantities with discounts. Normal procedure to collect orders initiated. You know what to do. (and if you don’t, just ask).
Pimoroni pHAT DAC for Raspberry Pi Zero
PRODUCT ID: 3016
Tiny OTG Adapter - USB Micro to USB
PRODUCT ID: 2910
1 of the #1788 MP3 shields
1 of the #1178 bearing set
Thanks!
I’m looking to turn a NOS AMI jukebox Wallette into an MP3 Jukebox and need the bearings for an eggbot I’m building. That just leaves me needing the rubber pieces for the cups.
I think the current interation of the eggbot uses a disc of foam with sandpaper to hold the eggs.
I would like 5 of these. I’ll add to this order later.
Here is my list of stuff I am interested in ordering. What will the prices be with the discounts? Thanks
Qty 2 - Professional Silicone-Tip Solder Sucker - PRODUCT ID: 1597
*** I had two of these on the last order but between the time I sent you Paypal payment and the order was placed they went out of stock again.
Qty 4 - Replacement Tubes for Professional Silicone-Tip Solder Sucker - PRODUCT ID: 2476
Qty 1 - Professional IC Extraction Tool - PRODUCT ID: 1598
Qty 1 - Adafruit Pi Protector for Raspberry Pi Model Zero - PRODUCT ID: 2883
Qty 1 - Raspberry Pi Zero Starter Pack - Includes Pi Zero - PRODUCT ID: 2816
Qty 1 - Ethernet Hub and USB Hub w/ Micro USB OTG Connector - PRODUCT ID: 2992
Qty 1 - Third Hand Pana Hand Workstation Add-On for Panavise - PRODUCT ID: 3019
Qty 1 - Panavise Jr. - PV-201 - PRODUCT ID: 151
Qty 1 - Hakko FX-600 50-Watt Adjustable Soldering Iron - PRODUCT ID: 3037
What is the planned deadline for ordering?
I was thinking April 22nd but open to suggestions.
In addition to this item I requested earlier, I would also like to order:
1 of #1946 - Adafruit FONA - Mini Cellular GSM Breakout uFL Version - https://www.adafruit.com/products/1946
1 of #1201 - Vibrating Mini Motor Disc - https://www.adafruit.com/product/1201
1 of #851 - SMA to uFL RF Adapter Cable - https://www.adafruit.com/products/851
1 of #1859 - Mini GSM/Cellular Quad-Band Antenna - 2dBi SMA Plug - https://www.adafruit.com/products/1859
Thank you! Sorry for not having this all in a single post.
I’ll workup a spreadsheet as soon as I can. It will allow us to have a live working document for our quickly growing list.
I would like to add to my previous post.
3 of USB Micro-B Breakout Board product ID 1833
2 of Vibrating Mini Motor Disc product ID: 1201
2 of Micro B USB 2-Way Y Splitter Cable product ID: 3030
1 of USB Power Only Cable with Switch - A/MicroB product ID: 2379
1 of Adafruit DC & Stepper Motor HAT product ID: 2348
Thank you for doing this.
We have hit the minimum of $250 for free shipping.
You can check or update your orders on the spreadsheet below. Please look in the notes column for your discount, no discount ;-( or out of stock messages)
We plan to close orders on the afternoon of April 22. You can pay for your items by PayPal: [email protected] or cash or check (put into locker in breakroom, PM me for the code if you don’t know it).
@themitch22, @Raymond, @Gimli, @Shawn_Christian, @rshill
Thanks!
One more thing to check price:
PRODUCT ID: 2232
I would like to order one of each of the following:
I can’t see any way for me to add these to the spreadsheet but if there’s a way, let me know and I’ll do it.
Thanks!!
@themitch22 & @mdredmond your items have been updated in the spreadsheet.
To update the google spreadsheet you can go here. Otherwise the one above will show the updates you make. You can edit it directly but the window is kinda small.
I’d like to get the following:
Adafruit 16-Channel PWM / Servo HAT for Raspberry Pi - Mini Kit https://www.adafruit.com/products/2327
Tiny OTG Adapter - USB Micro to USB https://www.adafruit.com/products/2910
Thanks.
Me too!
Adafruit NeoPixel Digital RGBW LED Strip - Black PCB 30 LED/m
PRODUCT ID: 2824
Qty 12
