I registered for Ceramics Handbuilding 102 for Nov 3 and accidentally cancelled my registration because I thought I had registered for the wrong date. Now I can’t register again… can someone help?
Looping in @Team_Calendar
Can someone please assist?
@mchou93- i only have 2 more classes both are christmas trees and are the same course. Is this the one you wanted to take?
Also @Team_Admin - @Team_Calendar - Can you please remove liz winters from my class on
As far as I know once you cancel you can’t reregister. The teacher can hold a place for you and can manually handle things.
@Team_Infrastructure is having someone cancel still taking up an open spot within the system?
I am not on Team_I, but I can answer, “yes, it is”.
“The teacher can hold a place for you and can manually handle things.” Since the class is both full and well over minimum of three, this seems like a reasonable way to go, i.e. if @mchou93 and @Synth83 agree.
Except it appears to be @dryad2b 's class …
I don’t know what it is but since COvid- it seems that even when people cancel, there isn’t a spot open for someone else to register.
@Team_Calendar and @Team_Infrastructure - can you edit the event so that I can either remove Liz Withers and allow for another person OR open it to include another space?
https://calendar.dallasmakerspace.org/events/edit/15987
There is an additional spot, now.
thank you so much!
