In the past, we were given the combination for the locker after taking the training class.
The camera is not in the locker. I presume it is locked in the big black cabinet. What is the current procedure for gaining access?
Currently the procedure has not changed, but most likely will.
At the moment, the top locker still has the same lock combination. If you open that lock, the key to the black cabinet is inside.
Just lock the key back up once you are done.
This setup is temporary
