RDWorks wants to scan the full width of the object being rastered, full left to full right. The burn below was going to take 2 hours using RDWork’s optimization no matter which settings I used for path optimization.
I instead organized my objects into layers where the carriage would move top to bottom several times in groups which would cut the actual time the carriage is moving without the laser on.
The grouping below cuts the time down from 2 hours to 22 minutes (based on simulation). YMMV - have fun. These seems to make an even bigger difference if rastering at lower speeds since the carriage doesn’t speed up between burns.
