Electronics folks, and especially RF gurus:
I am not an RF guru, but the industry has forced me to learn some things this direction to remain relevant. So I am hoping to poll the set of electronics knowledge at DMS and beyond to find answers to my questions about an RF item I stumbled upon ownership of, thanks to DMS freebie shelf.
Many would say its unrepairable. I disagree. And it is for a specific reason that I disagree, as outlined in the video that can be seen below.
My question are:
*Can anyone think of a way to bond the ceramic portion beneath the conductive cylinder permanently so as to fix the load once and for all? I am hopeful for mechancial robustness, but I might settle for fragile but functional.
*Are there good methods the experts know of to make sure that the electrically conductive portions of the system make low resistance electrical contact over the entire circumference of the break?
*What is silicone water as described by Bird? They use this for its dielectric properties as the resistance is submerged in this stuff I think. Can anyone tell me for sure if my understanding is correct? Where do I get silicon water? Or can I make some out of common items? How about not so common items?
*What is the fluid that gets pumped through the cooling coil? What pressure is required to get it moving fast enough to support 2500 W? How much heat must I remove from the cooling fluid outside the Bird so I can support 2500 W? Any suggestions for a piece of equipment that can do this?
*Do we have a piece of equipment that can inject 2500 W of power into the load? If so, can someone train me on such so that I can characterize and ensure that the unit I have can be used to sink this much power for an extended period of time? If no, where can I get access to such a signal source?
*From my reading about this subject, I have ascertained that with the power levels involved, an engineer must use extreme caution to avoid shooting large amounts of RF into the air around where I am using. There can be health implications involved. How do I ensure I am being safe here? What are the mistakes that others have made that are to be avoided? Can you point me to where I can get a good education on safety when dealing with large power RF signaling?
Here is a video I made that shows the internals of the Bird 82C and the damage that the unit I have has sustained:
Special thanks to our young maker friends Halee and Hannah. The intro for 3E8Tech has been created by Haylee and I think that Hannah has been involved and/or will be in the creation of high res improvments. The intro helps my professionalilsm a lot, and yes I heard you young prodigys about the snippet at the beginning, but heard it after I rendered this one.
