After the last Lemons event, our race car was left in only a partially running state, we are now meeting Thursdays at 7:30pm to work on the car, anyone is welcome to attend.
First step was fixing the upper timing chain, the guess was that I got the alignment wrong after swapping the head late in the night, turned out we were definitely a link off on the idler sprocket. Meaning the valves were opening / closing at the wrong time relative to the piston.
The red marks above were just to verify that the previous alignment was wrong, what matters was setting engine at TDC compression on cylinder 1, taking chain off, then matching the built in black links on the upper timing chain to the timing marks on the sprockets. The mark on the idler sprocket is on the bottom and not visible in picture.
That wasnât the only problem though, as it still wonât idle, mostly likely next issue is an intake leak as we used rtv instead of a replacement gasket for the intake. So next week will be taking intake manifold off (annoyingly difficult on this car). Will also be replacing thermostat and doing an egr delete (were forced to sawzall egr tube in half to do head swap, and currently an aluminum can + hose clamp is âreconnectingâ the tube)
After that will be diagnosing why the starter is nonfunctional (have been doing lots of push starting to test engine so far).
