Hi Guys,
I’ve got an intermittent starting issue. Whent it occurs the solenoid clicks and then nothing. No cranking at all.
Some details:
1). The alternator was replaced <1 month ago
2). The battery was replaced last weekend
3) before the battery was replaced the “Service battery charging system” illuminated 2
Tests this far:
1) The load tests at Orielly’s showed the battery, the alternator, and starter are working properly.
2) i voltage tested a few points, when I was experiencing a no start issue. I got 12.5v across the battery terminal. I got 12.5v from positive terminal to the engine block. Low but not horrid.
3) I banged on the starter and it still didn’t start.
Any ideas?
