I need to perform the following maintenance on my 2008 Toyota Camry XLE V6 and need some advice regarding the DMS facility.
1: I need to replace the CV axels…which is simple enough.
2: While I am at it, I need to do a brake job. It is also time to flush the system.
Looks like I will need a:
17-22mm socket,
30mm twelve-point deep socket
breaker bar
torque wrench
ball joint separator
flat punch set
pry bars
Do we have the above mentioned tools?
Also, what assist do I have to flush the system: looks like the standard 2-man job unless we have one of those single-person flush systems?
Finally, I may need to replace my power steering rack. Does anyone have the Toyota maintenance books? I understand that this may require engine removal?
