Why would that be the culprit if it is affected by fuel level?
That doesn’t follow, to me.
Yes.
As noted in the link from @kbraby for example a bad O2S heater might cause the CAT and O2S to also not be ready.
However, as also noted, weak battery could cause it as well.
Also, is the environment dropping below 90°F overnight? The overnight lows lately have only reached 79°F or so, and if it’s in a hot garage, it might not be cooling down that far during those few hours (far fetched, but possible). Also, is it sitting for 8hrs?
Testing the heater on the O2S is fairly easy, and is outlined in the videos I shared before.[quote=“jast, post:17, topic:10694”]
eric the car guy checks a 4-wire on a Honda;
checking an older 3-wire HO2S on a 1997 Nissan Maxima .
[/quote]
All this is outlined in the links provided previously, so I’m sure you’ve checked it all out, but since it’s still a problem, just going over it again…
