First issue was one that I caused. I sent a file that had some cutting in it while the engraving bed was in place. My sincerest apologies, but there is a faint marking in the corner of the metal bed. I was able to clean most of it off with a damp paper towel, I was afraid to try any chemicals on it. If anyone knows of a good method to clean the remnants off, I will gladly do it. The bed is still perfectly fine, just a cosmetic marking.
Second issue is that the camera seems to be off from where it actually does the cutting. Hard to explain, but I had everything centered where I needed it, and then it decided to cut half an inch over from where it was shown on the camera display. Has anyone else encountered that before or know how to fix it?
