At my sister’s house in OK. Brother-in-laws 1999 Jeep Wrangler 4.0L engine ~ 230,000 miles had the Check Engine Light come on. Code showed Misfire #1 cylinder.
Spark test for coil bar showed all good. Plugs all looked the same (mine with this same code error type had plug that looked very different from others).
So ran compression tests. Cylinders 2-6 were all within 10<psi of each other, approx 130-138 psi, BUT #1 was about 45 psi, did check several times. One check was to inject oil to see if rings would seal better and raise compression indicating bad rings. No change.
He’s putting it all back together now, my guess is it is valve. When back together, going to remove oil filler cap and see it there is some blow-back, indicating possible rings especially if it pulses. No blow back appears to be on intake so I’m guessing if valve it is exhaust valve.
Anyone experienced this: Misfire code indicating misfire due to low compression in a cylinder where plug is firing? Because the Check Engine Light came on now it seems odd that it would wait until there was 80~90 psi difference. Definitely a problem here.
Thanks
