Hi team. 96 appears to still be struggling to print level. I loaded the same print on Bubba and it appears to have printed just fine.
Thank you for letting us know, in the future place to report this is the issues and request section of talk instead of 3dFab
They can’t because they don’t have a green dot.
For future lookers-in
request green dot: #00-member-access-green-dot
report issue/request: #issues-requests
Sure I can do that. Thank you.
z=0 was about 2.5 mm above the bed. To whomever fiddled with the adjustment, please don’t do that again. Problem corrected last night.
Moving from left to right the nozzle is closer to the bed in the middle. I suspect the x-axis rod is slightly bent in the middle (~0.1 mm) from people loading filament without supporting the head.
