100W CO2 Laser (36"x24"x12") on eBay with spare tube
You may or may not find this interesting:
eBay Listing
Description:
Up for sales is my Morn MT-L960 100 Watt Laser Cutter Engraver. This is a great laser cutter and very accurate and productive. This is a big laser cutter with a cutting area of 24" X 36" and it has very low hours on it (about 80). I purchased this a year ago for a start up that never really took off and now it’s time to downsize. This system comes with all sorts of extras so be sure to read below.
Includes:
Morn MT-L960
Upgraded to the 100 Watt power supply and tube variant
Extra Unused 100 Watt Tube
Rotary Table Attachment
CW-3000 Chiller
Air compressor
Exhaust blower and ducting
Acer Laptop with Windows 7 and Laser Cutter Software
Laptop stand
Active Charcoal filter and blower
Black anodized cutting plate upgrade
Tools and manuals
Co2 Laser Safety Glasses
Would 100watt be enough to cut thin metal or dibond?
Probably not. I tried cutting Dibond with the laser and it won’t work. The power required to cut the aluminum (even at .012 thick) melts the plastic. It wasn’t even a clean cut. From what I understand with Dibond, using a router will give you the best cut. Check out page 24 on this manual: Dibond Fabrication
To cut thin metals you need at least 200watts and even the it requires a power supply that pulses to get the peak power to about 300watts for the start of cuts.
http://www.ebay.com/itm/100W-C02-USB-Laser-Cutting-Machine-Laser-Cutter-Engraver-Chiller-1400-x-900-mm-/221634392164?pt=LH_DefaultDomain_0&hash=item339a707064
http://www.ebay.com/itm/4x8Professional-Laser-cutter-engraver-machine-high-quality-free-ship-ON-SALE-/141504741744?pt=LH_DefaultDomain_0&hash=item20f2570170
