I drove my ‘08 3 to and from the folks’ house this weekend. Apparently on the return leg somewhere between a fuel stop in Texarkana and here the engine started making an unpleasant rattle at ~1000RPM and 3000RPM. I realize now that I vaguely noticed it inching along 35E then especially after exiting the highway in Lewisville. It’s RPM- and seemingly load/throttle-dependent. It’s distracting and hard to miss, but there’s no apparent (to the driver) tactile response; performance might be a tad degraded but I didn’t push it very hard getting it home.
I initially thought it was some underhood plastic pieces, but straightening those out did nothing. It also occurred to me that it could be bad gas, but I bought from Exxon rather than Local Sketchy Gas, Inc so I doubt it.
Did some checking on the all-knowing internet and oil deprivation was a suggested problem. Run the dipstick in and out a few times with liberal wiping and it’s coming back rather dry. I also now realize that what I thought was a patch of power steering fluid from the truck where the 3 parks is engine oil.
Will adding oil (then addressing the source of the oil leak natch) remedy this? Am I likely to need to learn engine repair? Or should I firesale it and look for a new daily driver?
It’s not going anywhere until I can at the very least get more likely sacrificial oil in it since I have a backup vehicle.
