New issues cropping up yet again.
!. I saw my coolant temp getting toward 212 F (boiling) and actually hit the number while idling. And this is AFTER 3 distilled water flushes. There is still something floating around in there causing blockages? Seems unlikely but possible. Or crappy thermostat that was new just a few weeks ago.
- Im stuck with EGR not being tested. Its been this way for a long bit now, many miles. Here is the listing to tests I just performed. Note that Test 2 CID 11 is missing:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$01 CID:$11
- Rich to Lean sensor threshold voltage(constant)
Max: 365
Test result value: 85
PASS
TID:$01 CID:$21
Max: 365
Test result value: 117
PASS
TID:$02 CID:$21
- Lean to Rich sensor threshold voltage(constant)
Max: 40
PASS
TID:$03 CID:$11
- Low sensor Voltage for switch time calculation
Max: 46
PASS
TID:$03 CID:$21
Max: 46
Test result value: 3
PASS
TID:$04 CID:$01
- High sensor Voltage for switch time calculation
Min: 0
Test result value: 92
PASS
TID:$04 CID:$02
Min: 0
PASS
TID:$05 CID:$01
- Rich to Lean sensor switch time(calculated)
Min: 0
Test result value: 72
PASS
TID:$06 CID:$01
- Lean to Rich sensor switch time(calculated)
Min: 0
Test result value: 113
PASS
TID:$11 CID:$11
Min: 34
Test result value: 480
PASS
TID:$11 CID:$21
Min: 34
PASS
End of report.
