Not related to O2 sensor:
I got a thermostat dial in from junkyard/ebay seller. This was a piece with a dial that fits into the dashboard. The trick here was that the numbers had to line up exactly in order for the part to function properly with the set of options that my particular Millenia has. There was only ONE of these dials available for sale in the entire cyberverse, and I got it. So, hopefully the thing works, right? I pllugged it into my dashboard as my dashboard was all in component wire-dangle mode and to my delight and surprise, the thermostat set temperature changed before my eyes! Now I can actually control whether to blow hot or cold no matter what the temperature is in and around the car. Fantastic! So from there I toggled out of dashboard component wire dangle mode, opting for reduced rattle fixed control/indicator position mode, which is the default mode most auto manufacturers use for new vehicle delivery to customers. Seems the customers want their dashboards with no dangling controlsā¦
So this was good news. Now for the less good news, which brings us to the O2 sensor related concern:
I have now tried three different O2 sensors plugged in to bank 1 sensor 2 position, all three of which have flagged trouble codes of varying severity. when the CEL lights up, the code is detailing a heater malfunction. At present, I have a brand new part in the bank 1 position 2 location, and so I am having to drill down into actual understanding in order to sort this one out.
After going to O2 sensor school, thanks to wold wide web, I discovered that O2 sensors output lower voltages for less O2, and higher voltages for more O2, as backward as that may seem. Its ok, however, since at the end of the day, the ECU can get a measure of O2 levels, albeit a little bit backward IMO.
But what really struck me upon my O2 schooling was this concept that exhaust leaks are just as troublesome as vacuum leaks since they yield erroneous O2 sensor readings. So for OBDII cars like this Mazda, the ECU really does use the values that come out of these sensors to control the fuel mix ratioā¦ This is important to me because according to my recollection, I just sorta slopped the exhaust back together when assembling the car. So I am starting to lean toward this notion that I may have an exhaust teak that is causing my O2 sensor codes. And Iāll also reluctantly admit that I have noticed a slight hesitation upon acceleration alongside a slight hissing noise I can hear with the hood opened.
OK, so I want to do an exhaust leak review on the car, as I believe this may be the last item I have to fix prior to inspection readiness (I pass all tests except for catalyst and evap, or at least I did prior to having all the O2 sensor troubles). This also makes sense in explaining why I never could pass catalyst, and all of these are likely prerequisites for evap.
So this brings me to my question for the auto experts: Now I had great success with the 'American Spirit" method I customized from Scotty Kilmerās āCigar Methodā for smoking out my vacuum leak. And I successfully used this method to locate and cure a vacuum leak at my throttle body, where I could see evidence where prior mechanics had squirted liquid gasket before. But I have concerns about using this method on exhaust. LIke I wonder will the smoke damage my catalysts, or maybe my sensors. Then, I wonder where I should insert the magical spirit smoke? at the tailpipe? Then it has to go through the muffler before coming to catalytic converters, then ultimately the headers. Is this a good idea? Is there a better idea?
Thanks all for the input! This project may actually end soon!!
