I want to take the tig class on the 21st. It says it requires a separate safety class to register. I dont see one on the calendar, but i’m already trained for the mig, is that acceptable, or do i still need to take the safety class?
if you’re in the MIG group you should be in the hot process safety group (might be called Welding Safety in AD still). That would set the flag that allows for taking the TIG class.
I’m unable to RDP at the moment, but maybe @StanSimmons can help.
-Jim
So i should be good to go, just need some computer things finagled up and then i should be able to register?
yeah. PM me your DMS AD username and I’ll get it taken care of if Stan can’t.
EDIT: found your user. you had been added to the MIG but not the welding safety.
Try again in about 15 minutes.
-Jim
Just registered! Thanks for the help!
