The definition and expansion of what constitutes “a writing” has a greatly expanded in the 200+ years (1817) since Calson was issued.
Texas statute more relevant and on point an covers electronic records, signatures and contracts. If YOU personally don’t agree to an electronic transaction you can opt out. As can the the other side for refusing to accept it as part of the bargain (try demanding a physical EUA to sign). DMS provides the option of physical ballots for you to exercise your vote.
https://statutes.capitol.texas.gov/Docs/BC/htm/BC.322.htm
Sec. 322.007. LEGAL RECOGNITION OF ELECTRONIC RECORDS, ELECTRONIC SIGNATURES, AND ELECTRONIC CONTRACTS.
(a) A record or signature may not be denied legal effect or enforceability solely because it is in electronic form.
(b) A contract may not be denied legal effect or enforceability solely because an electronic record was used in its formation.
© If a law requires a record to be in writing, an electronic record satisfies the law.
(d) If a law requires a signature, an electronic signature satisfies the law.
Sec. 322.004. PROSPECTIVE APPLICATION. This chapter applies to any electronic record or electronic signature created, generated, sent, communicated, received, or stored on or after January 1, 2002.
Statutory Exceptions. Does it apply? I think it does. If you can find a statutory reference as an exception I’ll stand corrected. I couldn’t find a relevant one.
Sec. 322.003. SCOPE.
(a) Except as otherwise provided in Subsection (b), this chapter applies to electronic records and electronic signatures relating to a transaction.
(b) This chapter does not apply to a transaction to the extent it is governed by:
(1) a law governing the creation and execution of wills, codicils, or testamentary trusts; or
(2) the Uniform Commercial Code, other than Sections 1.107 and 1.206 and Chapters 2 and 2A.
© This chapter applies to an electronic record or electronic signature otherwise excluded from the application of this chapter under Subsection (b) when used for a transaction subject to a law other than those specified in Subsection (b).
(d) A transaction subject to this chapter is also subject to other applicable substantive law
Opt Out of Electronic format: YOU personally can always use physical ballots, DMS provides these for members. You can do it on a case by case basis. When we “signed” the DMS kiosk waiver, that was electronic, when we joined online, that was electronic. When we joined TALK that was electronic. DMS has electronic agreements with members often and they are binding under this statute.
322.005. USE OF ELECTRONIC RECORDS AND ELECTRONIC SIGNATURES; VARIATION BY AGREEMENT.
(a) This chapter does not require a record or signature to be created, generated, sent, communicated, received, stored, or otherwise processed or used by electronic means or in electronic form.
(b) This chapter applies only to transactions between parties each of which has agreed to conduct transactions by electronic means. Whether the parties agree to conduct a transaction by electronic means is determined from the context and surrounding circumstances, including the parties’ conduct.
(c ) A party that agrees to conduct a transaction by electronic means may refuse to conduct other transactions by electronic means. The right granted by this subsection may not be waived by agreement.
(d) Except as otherwise provided in this chapter, the effect of any of its provisions may be varied by agreement. The presence in certain provisions of this chapter of the words “unless otherwise agreed,” or words of similar import, does not imply that the effect of other provisions may not be varied by agreement.
(e) Whether an electronic record or electronic signature has legal consequences is determined by this chapter and other applicable law.
