We have been trained, when will we be able to use the new plasma cam?? It had an admin password on the processer when we were trained, is that still in place?
we found a bug in the software that is failing to work with user logins. We’re waiting to hear back from Dynatorch, but once that is done it will work.
Currently we found that when a user logs in the software resets all settings, which is no bueno
yep, that would complicate things a bit, thanks for the reply .
I took the class last week (Monday) and was wanting to cut this morning.
The system shows user dynatorch is currently logged in.
If the problem is not resolved, have we had any update on the status from dynatorch?
Once dynatorch has responded and the problem is resolved how do I get the password?
Thanks in advance…
We have not yet, need to follow up more aggressively
Stop by the metal shop meeting today and I’ll get you going.
-Jim
Thank you Jim – will check in with you next time I will be in the metalshop.
I was hoping to do some cutting today after work. Is there a way that can happen?
PM Me if you are still having trouble after the class.
I don’t see a class today on the schedule.
Are you saying I should PM you if I’ve taken the class?
Yes, to all that need access and have taken the class PM me. If your talk username doesn’t match your DMS one I need the DMS one.
Any update on this? Another day goes by as I can’t use the Plasma Cutter.
It sits there lonely. Wanted by unused.
