Free to the first taker, I can bring it by the space this weekend. 20gal Husky tank. Compressor died, I had planned to use the tank as a mobile air source but really don’t need it. Full disclosure, bottom is a bit crusty inside (borescope screenshot attached), but if that doesn’t bother you then it’s all yours.
I’m in! When and where should I grab the tank?
Are you closer to Makerspace, or Frisco? In case of the former I can swing it by the space tomorrow or Sunday, but if your closer to Frisco then we can both save some driving.
I’m closer to the makerspace, but I am passing by Frisco 121/DNT tonight and Sunday morning…so I’m pretty flexible on whatever is easiest for you.
I’m not far from either 121 or DNT, and will be home in the garage tonight
if you’re passing through. I’ll PM you my number if you want to drop by.
