Drill Press problem
I had a problem raising the drill press table. It seems the shaft is bent and does not engage the rack correctly. I’m happy to help with this but it will require two people since the table is heavy. I believe we need to replace the shaft and the pinion.
A post was merged into an existing topic: [Issue]Woodshop Floor Drill Press has a broken part 8 Nov 18
