I have a complex bitmap logo that I want to prep for cutting on the Dynatorch CNC plasma cutter. I’ve pasted in the image into Corel Draw and it did a great job of converting to outlines. After setting outline color to black and removing all fills, I get the result shown below. Note that this isn’t the actual target image, but is representative of what I want to do.
Is there any utility that will assist in adding the supports/struts to do things such as anchoring the letters to the surrounding background? This is the same as one would find in a stencil set to used in spray painting letters. In addition to that I’d like to be able to set the width of the outline cuts that silhouette the letters and other features from the background. Google searches haven’t been fruitful yet.
I can change the outline width in Corel to get a step closer to what I need. But there are still additional steps needed.
- adding the support struts
- removing larger cutout areas to make it look good (this is an artistic/style step)
- generating the closed polygon paths that can be used by the cutter.
Any ideas would be much appreciated.
