Both machines use CAT 40 holders. As for retention knobs, I think they use the same retention knobs as your HAAS CNC machine. I’ll have to investigate once I return to work.
The 760 umbrella style ATC has a few pockets damaged. I believe pockets 1 through 4 are damaged, which is no surprise considering it made out of plastic, the 760 has a detachable conveyor/coolant reservoir system. The conveyor function does not work, coolant pump flood works.
The Torq 30 is currently not in use. We haven’t replaced the spindle motor. Although we used this machine for production in the past, on occasion chips would fall in between the way covers and trigger the limit switches causing the machine to alarm out and you will have to re-home the machine.
